Typhon My 24 pound steel ramp.
Washington
I built a 50in x40in x 30in ramp out of some steel stuff, more steel stuff, and some rusty expanded steel. I bolted it together with some 1/4 20 bolts. It's not too heavy at only 23.84 pounds. And I can turn it the other way to do backflips.
I would prob do it with wood frame bc i have the tools for wood but not many for metal what tools did you use
I don't have that much but my dad has a ton. We have a lift and we are always fixing my cousins and brother's cars. I used a 11mm wrench to hold the nut side and a ratchet w/ a 11mm socket. All I used were quarter twenty bolts and nuts so the 11mm worked for every thing. Oh, and a makita grinder to cut the expanded steel.
I have a wood one too but its only like 1.5 feet wide and if I made it bigger it would be too heavy. I want to be able to move it around easily.
