- Wenatchee, WA
- 4x4-Mega
- BigRock 4x4
- Felony
- Granite
- Infraction
- Limitless
- Kraton 6s
- Outcast 4s
- Typhon 3s
- Voltage
So I wanted to share my frankenstein Arrma powered WLToys 12428 1/12 scale buggy build with you all. It has had many reiterations over the last few months and will probably go through a few more but here's the latest spec on it.
My goal for this was to make an FPV buggy build after I saw a badass video someone made of one with a camera mounted in the driver's position, RC sound simulator, and even a moving steering wheel. So I bought the 12428 1/12 scale for 70 dollars shipped to replicate the same build but afterward I realized that the car in the video was the 10248, the 1/10 scale version of the same buggy so quite a bit bigger. Still determined to make it work, I got to work with some pre-existing 3d printed designs that I've modified from other models to suit my needs, and even creating some new models of my own.
So in the end here it is. The truck is brushed and powered by the Arrma 4x4 Mega ESC, Arrma 7kg metal gear servo, and Arrma Mega 12T brushed motor and controlled with the Arrma Mega Tactic radio system. 3D print wise I've added my own designed vertical shock tower conversion mount, full sized lipo battery tray, custom full sized servo mount, custom mini servo mount for FPV camera, custom raised mounting tray to sit above the servo and drive shafts, and top tray to hide everything. I've outfitted a SG20 mini servo with Runcam Swift 3 FPV camera and by using a servo signal splitter the camera servo turns along with the wheels so you always see where you are going when turning and simulates first person head turning. In addition I've added rear tail lights, LED light controller set up for On/Off on channel 3, custom 3D printed tail light bracket with SMA antenna mount, and SMA to MMCX antenna cable connected to a 600mW FPV video transmitter off one of my old race drones.
Lastly, it has 115mm 1.9" crawler tires/wheels, Feiyue FY03 wheelie bar, 57T 32p steel spur gear, 17T 32P pinion, aluminum rear driveshaft, metal geared rear axle/differential from the Feiyue FY03, aluminium oil filled shocks, aluminum turnbuckles as well as larger adjustable plastic turnbuckles from the WLToys 10428 when aluminum ones wore out.
So there you have it -- my bastard frankenstein Arrma powered build. I will post my other Arrma builds later when I get caught up on other things and a few waited parts finally come in.
