Velodromed
Snatching defeat from the jaws of victory!
- Location
- San Antonio, TX
- BigRock 4x4
- Granite
- Kraton 6s
- Kraton 4s
- Notorious
- Outcast 4s
- Vorteks
- Voltage
- Infraction 4x4
I’m in South Central, Texas, San Antonio area and we have extremely fine Colicchie dust. The particles are microns big and get into everything. I got into these 3S cars over two years ago and something I’ve noticed is that the diff housing will typically become contaminated with fine dust in a matter of two or three runs, turning it into paste. Then it compacts in between the teeth, helping lead to uneven tooth wear and differentials stripping.
I’ve tried different methods to slow the ingress of crap, from sealing it with extra grease to using a lot of grease inside to absorb the crud versus using very little grease to hopefully not absorb much crud… haven’t had much luck so I decided to try liquid gasket to try to seal the differential housing area better. I did six differentials between three cars around 5-6 weeks back and opened up two cars recently to check
The first car I opened up over a week ago results were mixed and I couldn’t tell much of a difference, so I figured it was probably worthless to try further. But i jumped the gun because on the two cars I took apart over the last several days, three the differentials were impressively clean. Junk still got inside, but it didn’t turn into gritty paste.
So I’m doing the process again to two cars and I’m being far more careful applying the liquid gasket. I am also using very little superlube grease as opposed to a lot, just smeared it into the gear teeth and no more. I will open up the cars in six-eight weeks and report back. Another cool thing about the three differentials that stayed relatively clean is they were a lot easier to clean up.
The first differential below is how they typically look when I open it up. The longer it’s been running the worse it is. The second picture is a differential that was sealed with gasket maker and run for six weeks in very dusty conditions. The third is another differential that had a sealed case.
