PatMarcus172
- Solihull, United Kingdom
- BigRock 4x4
- Talion EXB
- Vorteks
Again, other more expert people will comment but your question sounds very similar to a post I recently started, here - https://www.arrmaforum.com/threads/...high-speeds-off-road.37282/page-2#post-517173Oh man that's best news I've heard in a long time. And does it take a full upgrade front end to truly track straight no matter the speed? Seems like it'll track diff at diff speeds
In summary, with a faily light weight truck, its hard to ensure. Thats the downside of having something that is also very durable precisely because its so light.
If you read the thread, you'll see lots of suggestions from bigger wheels that don't balloon as much (as this is one of the main problems with high speed control on the BR) to better shocks that make the car less "bouncy". You'll see that lots of people on this forum use and highly rate the MX28 Proline Badlands but theyre quite an expensive upgrade and changing to Typhon 6S shocks (also pretty pricey) is encouraged. Im doing the latter first, having managed to get some new Typhon shocks from an RC Breaker and will report back when the other required bit arrive (bushes and ball mounts) and they are "on."
A hugely beneficial cheap upgrade is switching to RPM A arms (you need the Typhon 3s BLX versions for the current model Big Rock). They can be hard to come by but place a pre-order and theyll turn up. Its not just because theyre damn near indestructible and A arms are a weak point on Big Rocks but because, unlike the stock arms, they have a second fitment point for your shocks which effectively lowers the height of the truck by a cm or so. This in turn makes it handle better and much less prone to traction rolls. Using Hub extenders which further widen the track can help, too.
Given how much the Big Rock wheelies on full power (unless you feed it in incredibly slowly), perfect traight line handling is going to be a challenge whatever the upgrades applied but you'll soon get used to it. I hear the new Vorteks is very predictable in a straight line at full speed so Im interested to hear what the magic formula is there.
