I wanted to share my build with some links and photos for who might be interested (or for inspiration)
- PRPRE005 Raminator Monster Truck PM1373 70kg Servo https://www.primalrc.com/product-prpre005
- Hobby Wing EZrun Max 5 https://www.hobbywing.com/goods.php?id=655&filter_attr=5456.6908.0.0.0.0.0.0.0.0
- Hobby Wing 56113SL 800kV
- 34T/34T pionion and spool from the limitless spoor gear (ARA310944)
- Flysky Noble FS-NB4 (www.aliexpress.com)
- 4xTemp sensors FS-CTM01 (Batteries, ESC & Motor)
- 1x Voltage sensors FS-CVT01
- m2c 3253 ARRMA KRATON 8 S 8MM SHAFT SIZE MOTOR MOUNT SLIDE https://m2cracing.net/60-arrma-kraton-8s
- m2c 3254 ARRMA LARGE PINION GEAR SLIDE
- m2c 3250 ARRMA KRATON 8 S MOTOR MOUNT
- m2c 3200 ARRMA KRATON 8S CHASSIS KIT
- m2c 3280 ARRMA S8 MAXX 5 ESC ADAPTOR PLATE
- m2c 3230 ARRMA 8S 20 MM ORING SHOCK PISTONS
- m2c 3215 ARRMA MOTOR MOUNT FRONT BRACE SUPPORT BRACKET
- m2c 3235 ARRMA 8S FRONT SHOCK SHAFT
- 20mi central ddiff oil
- 1 mill front diff oil
- 500k rear diff oil
- 45wt shocks oil
- Traxxas XMaxx from bumber TRX7735
- Custom Body paint (3 week of work!)
- M2C 3225 ARRMA SERVO SAVER AXLE
- M2C 3236 ARRMA 8S REAR SHOCK SHAFTS
- M2C 3285 ARRMA 8S FRONT HINGE PIN SUPPORT BLOCKS
- M2C 3290 ARRMA 8S REAR HINGE PIN SUPPORT BLOCK KIT
- Jims Cermamic Hybrid Bearing (https://jimsbearings.com/collections/arrma-complete-bearing-kits/products/arrma-kraton-8s-blx)
- Proline Trencher 4.3" Pro-Loc All Terrain Tires Mounted
It all started with this!
Thank you!
