SaltyLocal
- Thread starter
- #21
Yes, the steering feels extremely tighter than stock. Normal? Also, when I reattached the bolt to SS, it took all my strength to push the tension spring to even get the bolt semi-threaded. I feel it’s so tight that the threads aren’t lining up and now have to use a wrench to adjust. Isn’t it suppose to easily adjust by hand?Issue #3 is fixed with thermal pads (adhesive on 1 side) or even aluminum foil folded on itself.
Issue #2 Savox makes taller servos usually I think. Use a longer screw where the HR fixed link attaches to the servo saver arm and put like 2-3mm worth of spacers between the link and ss arm to raise the link up. Wiring looks fine.
Issue #1 Not sure I understand the issue here? Are you having a hard time spinning the wheels? Or turning the steering?
Will any thermal pads do and do I wrap the entire motor with them?I used these thermal pads under the heatsink and it tightens up nicely.
