Im new to rc ang got my first tyhpon 3s blx 3 2 week ago, but now my center drivshaft is starting to shred (ARAC3955) does anyone know if it posible to get a metal one and if so, then where?
Is this from rocks getting between the heat sink and driveshaft? I had that issue big time.
Ditched the heatsink and went to a clamp on fan mount and never had the issue again.
You could do a metal shaft but that is a bandaid to the problem (if that's it anyway) and you can still cut up the aluminum ones.
First kink is aluminum driveshaft.
Second link is the fan mount I use. Motor will run much cooler without the heat sink blocking the airflow as well. Win/win
Welcome to the Arrma Forum! I've got two 3s Arrmas & not had a problem with the plastic driveshafts, unless the slipper clutch/diff was too tight. Is it possible to provide a picture? Is it near the slipper? I tried an aluminum one & went back to the stock plastic one in my Senton.
