Dan B.
Area man
ArrmaForum Fan
Hospitality Award
Rig of the Month Winner
- Location
- Southern Vermont
- Fireteam
- Granite
- Limitless
- Mojave EXB
- Notorious
- Outcast 6s
- Typhon 6s
I bought this truck from Rich at The RCNetwork. It was basically new and he only ran a couple of packs through it for video on his YouTube channel. He installed the electronics minus the receiver, the rest was bone stock. I’ve been fine tuning, tweaking, and adding a few items here and there. Here it is as it sits so far:
Thanks to everyone here that inspired me, guided me, made recommendations, and just generally relieved me of my ignorance as I learned this new platform. Especially to fellow Mojave aficionado @SrC . And yes, I’ll have a windshield in the next body. Thanks again. You guys are awesome.
- HobbyWing Max 6 combo with 1650kv 4985 motor.
- 21 tooth pinion (Ran WAY too hot in the grass, was going to gear down but the fans have controlled it surprisingly well after I installed those.)
- Dual 40mm aluminum case Rocket fans on a PowerHobby motor mount with Team Brood 40mm fan guards
- AGFRC A80BHSW 36kg programmable digital brushless servo. Wow, I love this thing. Running on 7.4v from internal BEC, it is strong and FAST! I wouldn’t have spent that amount on a servo if I would have chosen it, but I’m glad Rich did!
- Futaba 3PV 3-channel radio with R203GF receiver.
- PPS-RC billet motor mount with pinion mesh screw adjuster, center diff mount, and roll bar mount. One of the most beautifully machined and engineered pieces of billet I’ve ever bought. Period. Porn for gearheads. Pricey but worth every penny, IMO.
- M2C 5mm extended hubs with the M2C serrated 17mm wheel nuts covered with the Hot Racing closed outer wheel o-ringed lugs. What a good combination, and it’s great that the center of the hubs no longer get clogged with mud and debris.
- Hot Racing aluminum servo horn and arm, AON48SH25 (Hot Racing does not list this as fitment for the Mojave, probably because the RTR’s come with that crappy Spectrum 23t servo, but it goes right in with any 25t aftermarket servo.). The middle hole on the horn is perfect, at least for my application.
- AliExpess front led light bar mounted to the rear of a bumper cutout (I cut out a portion of the front grill for the light.). This thing is bright!
- AliExpress rear billet 6-led red tail light mounted to the interior portion of the rear bumper. And like the above, this thing is bright! Helps a lot to let the driver know which way the truck is pointed in the dark.
- gens-ace-r-spam 8000mAh 100c 3s Bashing batteries, two of course.
- XT-90 connectors. I love these. Going to put them on every truck I have that runs 3s or higher.
- This thing is fast. I have to run it on 4s on my property because it can’t really stretch its legs and I can actually control it on my gravel driveway. Go to a wide open bash spot or sporting field on 6s and it’s an absolute freaking wheelie machine missile.
- I have not installed an additional cap pack or an external BEC, and I’m running the two 40mm motor fans and the front and rear lights (as well as the ESC fan) off the receiver. No brown outs or glitching as of yet, but I will eventually install an external BEC if it becomes necessary.
- I don’t do crazy sends with it, but with “regular” jumping it gets great air and is easily controllable in the air. Some say it’s hard/impossible to control a Mojave in the air, but not in my experience. It ain’t no Typhon, but minus any backflip attempts or crazy sends I’ve had no problems at all with it. And I don’t wish to destroy it, of course.
- I’ll be installing the ProLine belted MX3 Badlands on their (kind of ugly) Raid wheels when I trash the current tires. Expecting to maybe gear down a tooth or so. We’ll see.
- I feel the spring rates could be a little more aggressive, it’s pretty softly sprung IMO for a truck this heavy and this fast. Recommendations would be appreciated.
