- Mississauga
- 4x4-Mega
- BigRock 4x4
- Granite
- Typhon 3s
Got a Limitless.
Bought a hobbywing 150A and a spektrum 2050kv.
Team Corally 25kg servo.
Futaba r314 and 4PLS.
Using 2 3S spektrum 50c 5000mAh.
Infraction diff.
Got 72 mph with a 23T pinion.
Gone to a 1.7 primary drive ratio 27T pinion with 46T diff.
Rear shocks tight af. Droop screws tightened on front end and springs backed off.
No other adjustments or modifications.
Considering trimming the rear wing t reduce downforce on the rear. Leaving the extreme air dam front wing parts for now.
Please help.
Right now I have 10mm rake just sitting idle between front and rear (raked towards the front).
Anything else I should prepare for expecting maybe 85-90 mph pass tomorrow?
Taking her out one more time before we install a max6 and a castle 1717 on the stock spool.
Infraction diff.
Please help.
