My Kraton keeps losing gear mesh
Discussion in 'Kraton' started by BattleShrink, Jul 11, 2018.
Tags:
  1. BattleShrink
    BattleShrink Well-Known Member
    Mar 30, 2018
    28
    11
    Arrma RC's:
    Kraton, 4x4-Mega
    Got my Kraton last week. The top motor mount screw just keeps popping loose towards the end of one pack. Running 4s 5000mah 50c, ESC punch at 8, doing jumps. Using blue Loctite right now, have had to remesh it about 3 times already. I also switched to slightly longer screws from an axial bomber.
    [​IMG]
    Should I try red loctite? Get a hot racing motor mount? Let the blue loctite set for longer? Just torque the hell out of that screw? Could something else be going on? Thanks for your help.
  2. GuyFromCanada
    GuyFromCanada Premium Member!
    Apr 30, 2018
    222
    31
    Ottawa, Ontario
    Arrma RC's:
    4x4-Mega
    How long are you letting the blue loctite cure?
  3. BattleShrink
    Mar 30, 2018
    28
    11
    Arrma RC's:
    Kraton, 4x4-Mega
    Overnight, 15-20 hours probably
  4. Paultro84
    Paultro84 Well-Known Member
    Jan 24, 2018
    405
    172
    Arrma RC's:
    Outcast
    That's strange for running on 4s. What brand of thread lock are you using? I've watched a video from project farm on youtube where he tested different brands of thread locker in numerous ways and surprisingly Locktite was towards the bottom of the list.
  5. 2fast4u
    2fast4u Well-Known Member
    Sep 12, 2017
    98
    47
    Delaware, Ohio
    Arrma RC's:
    Kraton
    Threads clean, no oily residue or old loctite on them ? Shake your loctite well before using ? I use blue loctite and an L shaped wrench and it has a pretty good bow in it before I feel those are tight enough. Never had an issue.
  6. BattleShrink
    Mar 30, 2018
    28
    11
    Arrma RC's:
    Kraton, 4x4-Mega
    Hit the screw and mount threads with acetone and q-tips, reassembled, gonna let it rest until Friday. It worked itself loose from the factory also, on the second or third pack maybe. I was using Loctite brand liquid, shaken. I just reassembled it with some MIP threadlock gel that I haven't used because I heard it was a nightmare to unscrew haha, but that's what I want right now.
    Paultro84 likes this.
  7. ThatDrewGuy
    ThatDrewGuy Premium Member!
    Apr 18, 2018
    118
    65
    Chicago Area
    Arrma RC's:
    Granite, Kraton, Talion, Typhon
    Lol well if you put a bigger pinion on there, you would have to move it out anyway. Then the ridge of aluminum there would help hold it in place a bit more. :)
    2fast4u likes this.
  8. olds97_lss
    olds97_lss Premium Member!
    Dec 14, 2016
    382
    116
  9. WoodiE
    WoodiE Kind of good admin
    Staff Member
    May 14, 2015
    2,909
    1,902
    Lexington, KY
  10. olds97_lss
    Dec 14, 2016
    382
    116
    I have one of those sticks in my field bag. I used it as well off recommendation from you many years ago. Then I ran across the gel and have used it. The gel stays sticky/tacky for a while. If left long enough, it gets hard and can be tough to remove screws/nuts. Ends up sticking in wheel hub threads enough to where I don't have to reapply every time I take tires off.
  11. BattleShrink
    Mar 30, 2018
    28
    11
    Arrma RC's:
    Kraton, 4x4-Mega
    Whooo! It made it through a pack today! I ordered some Permatex gel in case the gremlins come back. This thing is awesome.
    ThatDrewGuy likes this.
  • Welcome to Arrma Forum
  • Disclaimer
