- Thread starter
- #41
Yay! Saga gears showed up today but so did a pair of 4s 5000 70c CNHL batteries my Limited project. Just for S&Gs I'm charging them both and I'm going to do the same "hopefully" 4 passes on the first battery as I did in the post above. The same with the second tomorrow. Front that point forward they are both dedicated to the other project. I just want to see if I notice anything spectacular. That and I don't have the time to let it cool down as it looks like the sky is about to fall out. On that note... I'll be back.
***updated below**
86, 87,86,85. I did them relatively quick as the sky was about to fall. It began to rain literally as I was packing up! I was checking the motor temps in between sprints. After the 4th pass, the motor temp was 142* All 4 cells were at 3.95 when I checked resistance, and voltage again at the end. As luck would have it, this is the pack with matching resistance in the cells.
This was done just out of my own curiosity, I am aware that my Turnigy 4S pack has 11 runs on it / cycles.
***edited to make comparison easier
***updated below**
