Heliguy
The hardware is the some of the best you can get as a normal person. I had the same question and did some research into it.
https://www.arrmaforum.com/threads/jerolds-limitless-build.49292/#post-704159
Synopsis
The screws are generally 10.9 hardness, which is the second highest. They could get 12.9 hardness but they are less ductile and will break easier. So this might be a trade off or toughness vs hardness. The problem is the design of flat and button head screws, they have shallow hexes. That combined with Arrma's thread locker fetish makes for a bad combination that leads to some rounded screws. Using socket head screw would better but there isn't enough room for that in all places... and it would look ugly.
It's best to hit any metel to metal screws with some heat before you try to remove them and don't use power tools or ball hexes.
Chinese specs don’t always hit the mark. Everything is always of the ‘highest quality’.
