Pfaulk54271
Behold the 4070 1570kv!!! Going in my Kraton ???
Holy crap that thing is long ?
What are the can dimensions?
You know I will!Wow, you gotta post some videos of that monster!
A little worried for my diffs ? I will probably start with 22/50 gearing, I'm currently running that gearing on my Leopard 4092 1480kv and it did 58mph with backflips on it. I'm picking up over 2000rpm and way more torque so it should work really, really well. I may start with punch on 1 and see if I can have fun. ?What is your plan for gearing? I run 20/50 pinion/spur with my tp 4070cm 2200kv.
It’s amazing how long a motor the tp 4070 is right?
40mm x 107mm
The first plan of my build was how to brace the rear of the motor due to the length and weight.
View attachment 32356View attachment 32357View attachment 32358View attachment 32359
Thanx man ?? I like to go through the pains and ? testing for people.@Pfaulk54271 i gotta jack this thread just for a sec to give @joostin420 some quick props. Dude, I know I’ve said it before but I love your builds. There’s buying manufactured parts and putting them on, like I do, and then there’s building like you and @Thomas P. You guys not only make some of your stuff but the sfuff you design and make has manufactured quality when you do it. Very inspiring.
I saw that and I may do something similar, looks nice.40mm x 107mm
Haven't had issues with this one noticeably moving on us yet, this is my brother's Kraton. I may do the 40mm bracket mod myself just to minimize any flexing.40mm x 107mm
How many packs through it and what punch level so far?I use hr bulkhead/gearcases and hr diff cups shimmed for all 3x diffs. I’m sure if I didn’t the diffs would have grenaded.
Check out my build log if you have not yet:
https://www.arrmaforum.com/threads/anyone-running-tp-4070cm-2200kv-on-6s.5381/
Max6 should handle it fine, haven't seen issues yet. Using a 30mm aluminum yeah racing tornado fan on it, running the 4092 leopard it has stayed very cool.Nice. It says it draws a max current of 230A. What ESC will you be using? I know the Max 5 is only rated 200A, not sure about the MM XLX. Watching this thread
Must be insane!I run an hw max5 esc, killmode 13,200uf cap pack, graphene 6s 6000mah. Default punch setting, and I would say about 8 or so runs.
