Kraton My new style body clips.
ilikehosewater
West side of NY state.
  1. Fireteam
My new style body clips. If you didn't see the thread on them, I figured I'd post them to a wider audience. I still need a few more testers, Hardcore bashers only need apply :)
They are made from 316L stainless steel, even in a salt water environment they will not corrode.
WyldCFH
  1. Kraton EXB
  2. Outcast 6s
@ilikehosewater
You are in testing phase of course, but a quick glance from my eyes sees a potential issue. The inside has no real provision to hold down the body leaving only the outside part of the foot.
You could bend the foot in say 1/8" then bend back out to give some foot on each side of the post.
I'm not a hardcore basher per se, but I drive hard and am learning to control in mid airand occasionally hit the skatepark
I have...
K8S EXB
Outcast 6S EXB
Typhon TLR
Corally Kronos XTR(same post/pin body mounts, no idea on size of hole and center to center distance)
Rivasl MT10(same post/pin body mounts, no idea on size of hole and center to center distance)
ilikehosewater
  1. Fireteam
@ilikehosewater
At this point I've been using them on my Kraton for about 2 weeks with no issue. I guess the question is, how many people rip the body up past the clips? Can anyone weigh in on that? I haven't yet and i've put more than a few yards of distance on mine, while on the roof. lol My first body had holes in the roof.
If thats the case, simply anchoring the helix would provide an enormous increase in area. How to do that? Not positive yet. As far as putting 2 bends that close together as you proposed would require a die set and a coining operation(fingers aren't up to that), and rotation of the clip would render the effort null. That moves this idea to the "probably not feasible" category. Again though, anchoring the helix is the better solution if that becomes an issue.
So, empirical testing it is. I should have a much better idea of how well they function in a couple of weeks. In the mean time, the increase in ease of operation seem to outweigh the possible drawback, at least to myself. As I said earlier in the thread, I've seen more than a few "good ideas" fail testing, this may be one of them.
Happy bashing!
Love those! And you could still attach a rubber tether to the loop.
Absolutely. As you wouldn't be pulling on the tether they might last longer.
