Since my last post changed to notehr topic i decided to create a new post
I got the rear shocks so far
Pros of the shocks:
1. Reuses the Original shafts
2. They are made of alluminum
3.will fix any leak issues of the stock shocks
4.they look beautiful on the back specially
5.reuses the original spring.
6. They are threaded shocks
Cons of the shocks:
1. I was not able to remove completly all of the air trought the bleeder valve
2. The endcap pivot ball are holded by.. 2 orings so a bit of wable
3. The shock internal orings are compressed a lot making the shaft a bit harder to move than stock
4. Du maybe because of the compressed orings the oil i used on my stock shocks feels a lot heavier in the back now will ahve to drop to 25wt(was at 32.5)
5. And the last. Lost approximatly 1cm of travel in the rear shocks my front suspension is always higher than the rear to match the setup i had before i have to completly thread the shocks retainers to the max.
6. I don't know the part numbers of the orings used and even if you could get every single spare part was a deal breaker for me at the begining.
I love how they look vs stock and they will fix any leakage issues of the stock shocks. The travel and rebound are heavy and slow now im going to lower my shock tune on the rear hopefully i can get the rear higher up without maxing the retainers i don't want to stress too much my poor springs because they are really working hard. Maybe you could use the stock o rings just fine befause they are compressed a lot and they are made of a softer silicone than the hot racing ones. I hope i can fix the hight in the rear because im not really happy about it
Edit: also about the pivot ball holded by orings remplaced them by thicker and smaller one si had from my wltoys 144001 making those orings useful. Took a lot of the slop out in the rear
Pros of the shocks:
Cons of the shocks:
