I will send you pic todayI'm guessing that's the washer ID. OD and thickness would be great.
I picked up some 3mm washers. They look tiny! Hopefully I got the right ones.
Thanks but I'm good. I installed them last night and they fit fine. I wish the ID was a bit smaller though.
Did you remove the stock washers, or use the 3mm ones in conjunction with the stock washers?
New truck should be here Friday, this will be my first Arrma. Here is a list of upgrades ordered and on their way. I will post pics as I build it up. If you can see anything I'm missing for it let me know
Tekno springs orange for the front.
Tekno springs yellow for rear.
Team Durango shims for the diffs.
Aluminum servo arm.
Fast Eddie Bearings.
4- 6x10x3mm bearings for steering rack instead of bushings.
Savox SW1210sg servo w/glitch buster.
VoltageHobbies Servo mount.
T-Bone Racing Typhoon front and rear bumpers.
Shock silicon TBD?....any suggestions mainly Bash.
Diff Fluid TBD?.....any suggestions mainly Bash.
Hot Racing Rear chassis brace
I will also post build on my YouTube channel Bulldog RC..
TIA for all the advice...great forum
Why did you chose the Savox SW1210sg servo w/glitch buster vs other Savox? like the sa-1231sg or the sc-1258tg are other that people have chosen. new and trying to understand. I just bash my Outcast
Anything else you need for the Servo to workThe 1210 is water proof.
Yea I did a cartwheel and stripped the gears on mineNot sure. I still run the stock servo. I just tightened the servo saver and it works for me. I may look into an upgrade if the stock one dies.
Yea not in to waisting money so as it breaks I will do what I can to bullet proof itJust stripped my second set. I think I am gonna upgrade.
Does the glitch buster that just plugs into the receiver work or do you think you need the type like castle makes? I think racers edge makes one that is just a capacitor that plugs right into the receiver.
What is the deal with T-Bone Racing? I ordered bumpers from them Feb 6th and my order is still in "New" status. Anyone else have delay issues? I did call 2 days ago (Feb 20th) and was told it was almost finished, but....
Do you know the part number for the mugen...tower has a set is this correct?
Sorry guys found the right forum on the correct part numbers...
Typhon tbone bumper
Perfectly inline with front wheels. Much better than the Kraton one that one was too big...
