Cater4anytink
Took my outcast out yesterday and after 30 sec it wouldn't move forward or backward..I've tried resetting the esc but it won't enter reset mode..any suggestions before I contact arrma
Sounds like you've striped something bra !!Hi everyone. New to Arrma, even newer to the forums. I think I might have an issue similar to this, except I know it's not throttle trim. I was bashing around in the snow (which seems to be the new norm) and hit a huge snow burm going about 40, did a back flip and landed. I must have landed at a weird angle cause it bounced and hit nose first on the pavement. Pretty normal stuff, nothing the Nero can't handle. But then I went to throttle forward and nothing. I got closer to the truck and heard a binding sound. Checked and everything moves freely by hand. I did notice that when I turn the front wheels the rear wheels or the drive shaft connected to the rear diff doesn't move. Any ideas? Thanks for your help.
I just purchased my Outcast last week and got the battery and charger yesterday. I connected the battery last night and went through the ESC settings with no problem as well as the throttle settings but tonight when I connected the battery I’m having what seems to be the same problem as others. I am not able to reset the ESC to factory settings and I don’t think that the throttle is setup properly but I haven’t tried to drive it yet. It wasn’t working at all tonight even though it was yesterday so I did the throttle setup again. I don’t think that it’s right I have had to do that twice. I was hoping to this weekend but now I’m worried that it might be something I won’t have control over and I don’t want to damage anything. Does anyone have any suggestions and/or live in the Dallas area that could help me?
Start by taking out the Centre diff pull it apart and check if it looks good do the same to the back.
As long as you go thro the esc programming it won't store the program until you power off the esc. This sets the program so when turning the esc off. There is a great video on the esc set up on YouTube type in blx 185 esc setup it' like 13 mins long but is the best video I've found to explain how to set up your esc. Hope this helps once you get the hang of the way you program the esc it's pretty easy.
Thank you! I found the video on YouTube and that helped me out tremendously!
Hello all, new to this, bought a Arrma Notorious, been playing with ot, lovely, forward, reverse, now i noticed , no brakes, i tried punching it settings, but got it all mixed up, Please help and advise how to set it to factory setting or to set it, to go forward, reverse and brakes thanks. Dion
