Ollie
All the sudden my car is not moving at all, I have tried tightening and loosening and nothing happens. Any ideas people
It’s seems as ignoring the back tires are tighter than the front what can I do mowTry popping the driveshaft out and see if it rolls any more free then. Tilt it up and roll it on the front two tires and then tilt it up and run it on the back two and see if there is a difference. If either the front or rear bind then you will know the problem is there...probably in the diffs. If both are free then it's the motor or the transmission.
Not I. I don't think I've ever posted a youtube video before.@WoodiE I think you have to post it on YouTube and add a link to it.
OK GREat will try and find a video on how on how do that. Thank you for the informationYep that worked. I don't believe I have rolled my Granite...or if I have I didn't pay attention to the sound and feel....the front doesn't sound like that?
If it doesn't then it is the gears...you maybe have stripped a tooth or the mesh is off in the rear. Your best best is to take the diff out and inspect the gears.
