When replacing servo use a Savox waterproof servo. Your troubles will be over.Check for play in the servo saver, Hot Racing pivot balls, new servo, replace bushings in the steering bellcrank with 5X10X4 bearings.
you can kind of fix that by putting a little bit of electrical tape over the holes on the botten of the rig. that way you can just pull off the tape when you ever need to unhook the steeringDoes the servo lock up while running the rig? every once in a while small rocks can work thier way into the bellcrank and servo saver area.. Thats if its happening on that type of terrain..
I think you have to be more specific. There are many things that affect steering/handling. There are many upgrades and fixes for steering/handling. But it's hard to know what kind of problem you're having without more specific information.Wheel sizes?
