- Granite
- Typhon 3s
- Typhon TLR
- Voltage
My Typhon hasn't been getting much love lately so I decided to change things up and make it 2wd. It's a blast to drive so I figured I'd share the build and files in case anyone else is interested.
My goals:
My goals:
- Rear-wheel drive
- Lightweight front end
- Wide front track
- Narrow rear track with meaty tires
- No permanent changes (can easily revert back to stock)
- Removed diff
- Removed driveshafts
- Designed plug for diff location (3D file)
- Designed stub axle retainer (3D file)
- Redcat 17mm hex with 6mm extension (part #BS936-003)
- RPM arms (stock length)
- Stock links
- Stock tires
- Tightened slipper clutch
- RPM arms (narrow length made for a Granite)
- Narrow links (from a Granite)
- 2.8" Pro-line raid wheels with 17mm insert
- Duratrax Stakker tires
