Typhon My Typhon 3S build begins
UK
  1. Typhon 3s
So here we go, my first RC for 30yrs, straight in with a Typhon 3S and I'm really looking forward to getting right into the whole RC scene again.
Anyway, a few pics, be kind 😂
In stock trim, love the look of this buggy
A few touches added today
And a little added protection, thanks to Arrmaskinz 👍
Kingleo619
San Diego, ca
  1. Typhon 6s
Welcome bro...the addiction to speed will have you going 6s after a couple wks 😂watch the next post will be" what 6s combo will fit in 3s typhon" happens to all of us unless you are firm on the decision you make.
rag6
Pittsburgh PA
  1. Felony
I did the same... I used silver compound for drifting, but your gonna need a bigger pinion for the smaller tires. 20tooth works, but go a little bigger if you can. Mine feels around 45mph with the 20 tooth using the hoons... And feels like 60 with the stock tires on the 20 tooth...
UK
  1. Typhon 3s
Thanks for that, is it an easy job? Running stock pinion on the Hoons will have what effect, slower top speed?
rag6
Pittsburgh PA
  1. Felony
I never ran the hoons on the stock 15t pinion. I assume it will be painfully slow. Hoons on the 20t seems pretty good, but nothing to get exited about. I'm not sure what the biggest pinion you can fit is, but next time I'm at my local shop, I'm gonna grab a 22 tooth for the smaller road tires.
It is a very easy swap. 1 screw to get the motor module out of the car, a few more to expose the gears...
For stock tires on dirt... The 20 tooth is a little to top end(ish) for my taste, and acceleration from low speeds feels like turbo lag to me. I did pick up an 18t for stock tires. I installed it, but it's rained every other day since, and our bash track hasn't dried out enough to run it. I have the stock 15, and also 16,18, and 20 to work with. I've a feeling that a 17t is gonna be the sweet spot on our bash track, but I'm gonna try the 18 1st...
UK
  1. Typhon 3s
So I'm doing my own body in pearl white very soon and in preparation for it I thought I'd give a new wing a try, I think it's gonna work great against the white 👍
20210531_135732-jpg.149268
