- Kraton 8S
- Mojave
- Notorious
- Senton 6s
- Talion
Well , long overdue for a total strip down/inspection , the chassis being bent ( from day one by leaving the plastic chassis braces ) THEN upgrading to the aluminum , and inspect the bearings , etc . I have already upgraded to RPM arms , fr and rr T-bone bash bumpers , M2C acherman arm , heat sink / fan combo .
I am the guy who usually never replaces until it breaks , thats why it still had the orig servo / esc / and motor ( we all know about the radio ) so my Futaba 3PV was my choice as I already had it in my other RC's.
I will go thru the diffs / shocks again but will wait to install the new M2C pistons as I want to drive it then change them to see the difference . Decided to go with the 35kg servo and the new EXB heavier servo saver spring but will re-install the orig BLX esc/motor combo with the 16t pinion .
This truck has been bullet proof for me , never lost a diff or electronics . I know all the hype now about the LSD's , but I'm fine with the tried and true diffs , tune with thicker fluid method , I almost pulled the trigger on a new EXB Talion but figured invest a little into my V4 and make it better ( especially the chassis !!! ) and not impressed what people are saying about the new Spektrum stuff .
Here's the start !!!!
