I'm confused as well...I don't understand how you break your truck in so many ways. This is video worthy. I really want to see how hard and high your bashing is because you must be a maniac and never afraid to send it.
Do they make shock tower braces for the 3/4s models? If so I'd buy em and lose the tower to tower Brace. But then again I don't know about the non 6s versions...My friend has a kraton 6s v2 and he doesn't jump more than 3-4 feets or backflip it and says im craxy when i backflip lol but when i nose land at 6-7 foot jump it pisses me pff maybe the chassi brace has something to do?
Do you have the files for the 3d printed part for the motor? Did it resolve your issue?I’ve only bent my mount once on a nasty head on crash into a thick telephone pole at 45mph. Nothing is going to survive something like that unscathed.
Nope.Do they make shock tower braces for the 3/4s models? If so I'd buy em and lose the tower to tower Brace. But then again I don't know about the non 6s versions...
True my friend it bends where the motor is onlyIt is crazy how 6061 aluminum can be soft. This motor mount seem thick enough though. In 7075 it wouldn't bend like that.
But, we must understand in which way the motor mount bend. Is it mainly on one side, in this case the motor should be hold to stop moving up or down or on the sides. Or the motor mount is bent with the same angle on both sides in the same way, in this case it could be bent by the weight of the motor mainly on hard landing on the front end of the car. In this case, something just behind the motor should prevent this.
I don’t think the filament I have will work well for the rear motor mount idea. It is too brittle and it also makes the motor hotter. It needs to be a metal piece to dissipate heat as well as hold the can. I think this is a job for a machinist, which I’m not.I just saw a reply from someone on the forum about the arrma and HR adjustable motor mount and he bended both.. i will try the 3d pring thing to prevent the motor from moving
Hee goes all my hopes down the drain then
My suggestion was going to be to stop nose diving.If you watch my Kraton 4s BMX track video, I lawn darted it hard enough to break the rod end off the center brace as well as bend it. The motor mount (stock) was perfectly flat. If you are constantly bending mounts, maybe you might not want to be sending your truck. The skill level just isn't there just yet. You must be pile driving the truck into the ground.
I just boiled mine for 5 min then made em straight then ran cold water over them like Rpm said to do and they are flat now.I gotta say that my level of driving has GOT to be the WORST in the world. Lawn darts are half of my landings. Like I said, I’ve only been able to bend one motor mount and that was a head on pole crash during a speed run at 45mph. That crash was understandable as far as damage.
Last week I destroyed a chassis doing lawn darts on my Typhon (the final straw was a rear landing). Just tore it down last night and replaced the chassis. The motor mount was perfectly straight. The tie rods and a-arms are all crooked as sh!t, so those were addressed too. At least the RPM arms didn’t break. They are just warped all to hell. Swapped them side to side and hope that straightens them.
I have a spare set that I am probably going to boil and set. Then I can replace the noodle ones and boil them too.I just boiled mine for 5 min then made em straight then ran cold water over them like Rpm said to do and they are flat now.
Oh I’ve nose landed everywhere I run. Pavement, rocks, dirt, grass, you name it. I’ve lawn darted from at least 15ft, but probably 20+ft off my ramp. The full speed grass jumps I was doing last week claimed two a-arms back to back on the Kraton plus a Typhon chassis. No motor mounts harmed. As soon as I get my arms, the Kraton is going back to that hill will Backflips on. I may use the ramp instead for jumping because the face of that grass hill isn’t flat and linear. It has ripples and I’m pretty sure they ripped my arms, not so much the landings.Idk why mine bends so easy like i said i only nose landed once yesterday
Maybe if you nose land on grass it wont cause any issues
Maybe i should remove the chassi brace then idk razor spoke about is chassi brace being rigid somehow and not allowing any flexOh I’ve nose landed everywhere I run. Pavement, rocks, dirt, grass, you name it. I’ve lawn darted from at least 15ft, but probably 20+ft off my ramp. The full speed grass jumps I was doing last week claimed two a-arms back to back on the Kraton plus a Typhon chassis. No motor mounts harmed. As soon as I get my arms, the Kraton is going back to that hill will Backflips on. I may use the ramp instead for jumping because the face of that grass hill isn’t flat and linear. It has ripples and I’m pretty sure they ripped my arms, not so much the landings.
I have mine on still. However, I don’t know if this matters, but mine is on backwards. ??Maybe i should remove the chassi brace then idk razor spoke about is chassi brace being rigid somehow and not allowing any flex
