- North Liberty, IA
- Infraction
- Kraton 6s
- Typhon 3s
- Typhon 6s
Good evening arrma fam!!!! I finally got some 8mm pinions in today & the Toe Cutter is all ready to go. Waiting for some warmer weather to give er hell. My 1st half a dozen or so runs w/ the new setup have been all trigger finger so I haven't really used all of the nb4's potential yet.
My question is this- is there any way to abort a run if something goes wrong or if something doesn't feel right? (like me chickening out) Or will it just continue on to 100% throttle? Can I just hit the brakes & have the car slow down to start over?
Also, my gear calculator says w/ this setup I should get about 130 & that's a pretty big jump from the 107 I did w/ the old setup. Could I just limit throttle w/ the nb4 as well, using the throttle endpoints then work my way up to 100%? I also have the b-link thingy too, but I think it would be easier just to use the nb4. I really appreciate any guidance you speed runners could throw my way
Running a single 6s 90c 8000mah cnhl to an xlx2. Tp 4060cm 2610kv w/ gp5 diffs f/r & 24t/34t center spool
