jkflow
TB RC Bashers
Hospitality Award
Surprisingly its metalAre the spokes actual metal or just silver plastic?
@Engineer worked out like a charm. Just needed to find a very, very small washer since the center hole was a bit larger than stock for the center screw...used a 2mm nylon washer. Thx
@Camaroboy383 I'm good Sir so disregard...thx as always!
View attachment 202286View attachment 202287
I did this to my DX5r the other day. Adapted a touring car wheel to fit. I prefer the larger wheel and the 42 shore foam feels good in the hands.
A little bit of epoxy, an unused hex extension (12mm hex, 8mm thick) from one of my crawlers, and a longer screw is all it took. The DX5r and DX5 Pro have a bit of a different shape where the wheel attaches...they use a small hex, whereas the DX5 Rugged and the DX5c use a square, but the method should be pretty much the same, as they all have the wheel backing plate (cam plate). It's important for the hex extension to have the circular base on it, as this will center the hex between the 4 little "tabs" on the wheel backer.Details man! I'd like to do that with my DX5C. Not particularly fond of the stock wheel on that transmitter.
