need a new rear hub carrier for 2wd platform
justatree
Are there any metal/ aluminum upgrades? I threw dogbones 5 times in 2 hours... sheesh... halp, stripped out rear hub carrier screw socket
Dreadstar
Glasgow,Scotland
You really need to upgrade to turnbuckles with RPM 4-40 ball ends for the chassis side and captured rod ends for the hubs. Depending on where you live,I could send you 4 off captured rod-ends.
justatree
I think I might do the ajdragon rear camber link mod where I get longer ball studs and put a lock nut to keep it from backing out
thanks for the offer though Dreadstar
ajdragon
  1. Raider
Hi
I ended up going to captured ball ends myself when I got better tires. The better traction from the tires was just ripping the standard ball cups off the ball studs every time I made a sharp turn.
justatree
Hi
Hi, can I have a picture?
I still run stock gearing so I think I will be Ok, I do have the rtr traxxas s1 tires on which are somewhat grippy
Would you think it would pop off?
can you also provide me the links
I have never thought of this, but will look into it if these fail
ajdragon
  1. Raider
Hi
You can use any 3mm captured ball end.
I used the captured ball ends from my steering since they were not working right in the front. As you can see in the picture it's a easy up grade.
