This is the diff pinion gear( please excuse my lack of termanology). Is that in as bad a shape as I feel? What would make them eat up so sharply? I had white lithium grease on outer diff case. Won't do that again. Gunky. Thick af
Yes should be fine I'd just take it easy the first few minutes you run it to let that spot wear in and smooth itself outThanks guys. So just backing off the yoke screws to free up the mesh? I put a whole new diff in I had. Same pinion gear. So if ive got it free with just a small catchy spot should that wear in a bit due to the funny teeth on pinion ⚙?
