NEED HELP! Nero diffbrain rear diff locking when supposed to be unlocked
RCMANIAC147
I recently replaced all the bearings in my nero, and when I put everything back together, my rear diff was locked in un locked mode and un locked in locked mode. I tried to plug in other diff brain servos and the same thing happens. I reset everything to factory, I messed with the end points. I also plugged in the rear servo to the front servo area, and it does everything like its supposed to. It's only when it's plugged into the rear diff part of the diff brain.
lonee
Germany
  1. BigRock
Do you adjusted the diff brain board also?
  • NERO DIFF BRAIN CONFIGURATION 20160704.pdf
