So I tried to set up my new Notorious. It’s a new old stock V1. This is my first hobby grade RC car. I did my best to follow the instructions but they were very difficult to follow. I was able to find a video on how to set up the steering trim and got that set up. I figured out how to set the punch control and the ESC settings. My issue was that the cars throttle would be reversed some of the time and the right way other times. I was able to drive the car around the house. Then if I turned the TX off, the car would go full throttle until I turned the ESC off. I didn’t look at what direction it was going as it was bouncing around and slamming into everything.
After chasing the car around my living room 2 times and leaving rubber marks on the couch, stereo speakers, entertainment stand, and rug, I decided to call it quits for the night and seek your help. I had the car up off the ground during the programming, but the wheel spin knocked it off the stand and it took off! The other time it was on the ground after running around the house safely, and I turned the TX off, then it took off! What settings should I have the car set to.
Here are how I had it set up.
ESC:
1: Lipo
2: Level 5 (I want a little juice)
3: 50% braking
4: Fwd/Brk/Rev
5: Normal (CCw)
Tactic Radio Settings:
Ch1 St= Nor
Ch2 Th= Nor
I did not set my fail safe.
I did a factory reset on the TX and the truck and took the batteries out and put it away!
ESC:
1: Lipo
3: 50% braking
4: Fwd/Brk/Rev
5: Normal (CCw)
Ch1 St= Nor
Ch2 Th= Nor
