Which radio are you using?Need help sometimes reverse doesn't work, even when I try to pull the trigger twice, or even when Im at a full stop, it will work randomly, but when I need to, even if I pull the trigger reverse several times it doesn't work.
Yes. Throttle trim needs to be neutral!Stock! And ive tried to switch the direction on the remote, so just to see if the switch is the problem. But nope.
But yes, I have throttle trim at max, could that be it?
