Raider Need help starting my raider xl
mudman
  1. Raider
If the slipper clutch is too loose the wheels may turn while holding it in your hands but once you put it on the ground there is too much resistance for a slipping clutch to overcome.
ssmiljanic
  1. Raider
  2. Talion
I remember when I bought my first hobby grade RC, a Traxxas Grave Digger, the slipper was loose and I thought the truck was broken. It's been a steep but fun learning curve since then. The manual should show you how to tighten your slipper. A bit hard to find, but Tighten down fully (but not too tight) then back off three turns. Best of luck
