Kraton Need help wanna drag race a kraton
Supasteve
What kinda diff spur tire size can i run to get top speed on pavement with stock motor and esc
I am running 22 tooth gear with stock diff gear i believe is a 50 tooth and the smallest tires i can possibly fit
I have a 43 tooth im thinking bout changing to
Most speed runners people use something like the motor setup in my Kraton: tp 4070cm 2200kv with hw max 5 esc or castle xlx esc, and cap pack. I built my Kraton full out for reliable running. Time, effort, money and you will be happy ;)
There is a speed calculator in the body of this YouTube post I use:
check out my build logs for information that could be useful:
kraton build: https://www.arrmaforum.com/threads/anyone-running-tp-4070cm-2200kv-on-6s.5381/
senton build: https://www.arrmaforum.com/threads/anyone-running-leopard-4092-1730kv-on-6s.7869/
Ok thanks i will check it out when i get time im trying to use stock motor and esc for now
Im already beating stock arrma senton and kraton but i wanna push stock as far as possible then im gonna go with an 8s setup
How fast have you had the kraton
This is the calculation using the worksheet for my configuration:
The videos don’t do justice as to speed. It is by far the fastest driveable truck I have built in 30 years of the hobby. Smile on my face every time I drive it :)
That is much faster than I expected, I am looking at the basic tp 4070 ...that would be enough for me..lol
How well do you think that rear motor mount would work with bashing? Do you think it would need a t2t brace also.
But you didn't film the part where you made those sick burnouts!! :ROFLMAO:
what is the set up far as piston, motor,esc that you are running ?
Question what motor and speed control would you upgrade to for a kraton. On 6s I cannot find a 2200kv monster mamba 2 anywhere. Could you recommend me a fast motor and speed control set up please. I plan to use the 20 tooth also ?
