Found on YouTube. First timer here
Now tell the story. What was the issueFound on YouTube. First timer here
Only issue was me not knowing what I'm doing.Now tell the story. What was the issue
Should be a set screw. The retaining clip is just in case the set screw gets loose, so the pinion doesn't fly away.No, I'm sorry. I don't have push notifications turned on. Ok so like it said I'm a complete noob at doing this. When I looked into my other blx it looked like there was a lot of extra antenna cable in that receiver box. To me it looked like the wire just came out of the box had a grub screw holding it down on the outside of the receiver box. I sadly didn't know that the antenna wire was ran up into the black antenna housing next to that grub screw. I had never taken the battery tray out before and seen that that's how it's ran. My bad about starting the post and then editing it to found. I guess I should have deleted it.
Curious about something. What stops the pinion gear from sliding besides that retaining clip, just red loctite?
Looks like ur gonna be making some bukuu money bro, love the enthusiasm!!Blue gel? I'll look into that. I plan on being the only mechanic to work on these. I've taken them apart and put them back together so many times. Lots of learning you can't tighten this first because you have to do this before that ECT. Thank you guys for your input. You're quick to respond which is awesome.
This wonderful stuff: https://www.amazon.com/dp/B0053ZNMDEBlue gel? I'll look into that. I plan on being the only mechanic to work on these. I've taken them apart and put them back together so many times. Lots of learning you can't tighten this first because you have to do this before that ECT. Thank you guys for your input. You're quick to respond which is awesome.
I'll pick some up, thank youThis wonderful stuff: https://www.amazon.com/dp/B005
Wow, that site has a very extensive selection of hardware. those anti-vibration threaded screws look like they would be nice for bashing.Grub/set screws can be obtained (mcmaster.com) with serrated tips to prevent back-out. I don't put RED loctite on anything unless it can be easily heated for removal. Blue (or better yet blue GEL) is plenty good for holding things together between disassemblies. If in doubt, re-torque after one run. Keep in mind who your mechanic is, and decide whether he's gonna be happy you used red thread locker...
I keep one of those in my pit bag to use when out bashing.I'll pick some up, thank you
Thank you for the tips. Thinking about picking up a PPS motor mount. What is the difference between blue loctite, blue gel and the blue stick from the post above that mentioned it? The orange works better than the blue and heat is not necessary for removal?I keep one of those in my pit bag to use when out bashing.
I use gel when at home:
https://www.amazon.com/Permatex-24010-Strength-Threadlocker-Applicator/dp/B000HBM564
I use orange when blue isn't enough, but heat is hard to apply without damaging something near by:
https://www.amazon.com/Permatex-25210-Strength-Removable-ThreadLocker/dp/B07R6B87S5
Ok. Thank you for that info. I'll have to pick some up soon. I wasn't a fan of that runny liquid either.For me, the standard blue watery stuff just gets everywhere, so I quit using it. The gel is a larger tube than the stick, but both work equally well. I just have the stick since it's small for my pit bag. The gel and stick seem to work better than the liquid, especially on things with larger threads like wheel nuts.
