Senton Need help with my senton 3s
Hatchetman37
  1. BigRock 4x4
  2. Granite
  3. Senton 3s
How can I deep clean my motor? It was recently submerged for a few sec. Now it bucks and chugs
Jon NC RC
Keep it fun......SEND IT
In the stix…NC Mtns
  1. Kraton 8S
  2. Kraton EXB
  3. Mojave
  4. Senton 3s
Sorry, misread your question
If you need a new motor, go to Jenny's RC, you won't find one for less unless you have a friend that has one to give you.
There will be no warranty if you get it from jenny's, but it shouldn't be too much I would think
palmryde
  1. BigRock 4x4
  2. Granite
  3. Typhon 6s
Do not see why you can't carefully take it apart, remembering where everything goes. Clean with electrial contact cleaner and replace the 2 bearings. Re-assemble and test. It may be fine. Did your esc get submerged as well? Those are not waterproof. Good luck
ZooKeeper
Quack!
Chicagoland Burbs
  2. Granite Mega
  3. Infraction
  4. Kraton 8S
  5. Senton 3s
  6. Typhon 6s
Similar to what @palmryde said...
When I deep clean my motors, I completely disassemble them and clean all the parts in a heated ultrasonic cleaner in a solution of 1 gal water + 1 cup Simple Green. I run the ultrasonic part for 5 minutes, rotate the parts around to change their orientation, and run it for another 5 minutes. Pull it out and let dry. Give it another clean with electrical contact cleaner to remove any residue from the Simple Green. Clean the bearings separately and re-grease them, or replace them.
Before you ask, yes, I throw all the parts into the cleaner, motor can, can caps, and rotor.
Hatchetman37
  1. BigRock 4x4
  2. Granite
  3. Senton 3s
I'm no expert but I think you need a new motor.
Thus is my fear as well
Well it does have a chassis cover on it you know the mesh cover so that slowed down the water some I don't believe the esc was hurt .
