- Points
- 368
- Tennessee
- Granite Grom
- Kraton 4s
- Nero
- Outcast 4s
- Talion EXB
- Infraction 4x4
So I need some help here. I bought 2x HP 750w server power supplies off eBay. Before I started to do the conversion to wire them into series for 24v output, I did the 33pin and 36pin “trick” to make the power supplies turn on. I checked the out puts of both power supplies, a steady 12.3 volts each.
I label them as slave and master, as the slave is the one to float the ground to allow for 24v when wired in series together. I go through all that and the slave power supply now has a floated ground.
I now go to recheck the slave power supply voltage output and it’s all over the place. Starts off at 12.3 goes to 2.4 drops to zero jumps to 11.1 drops to 5.6 etc. Is that normal for the power supply with the floated ground? Or have I done something wrong?
Please help!
Please help!
