Typhon Need help with shock oil
piccopower
  1. Outcast 6s
My Typhon 3s front end when pushed by hand goes down and up real quick… the back end goes down slow and returns slow… what do I need to fix the front?
piccopower
  1. Outcast 6s
Is it the shock why that’s not allowing it to travel down slowly? Like the back shocks?
gotnitro
1st place
You need to open up your front shocks and check the oil. Then you have to adjust the ride height with the nut tensioners on the shock body. You want your ride height with your chassis about level to the ground.
