Need help with wheel nuts!
arrmary
New Member
  1. Outcast 4s
I'm looking for a set of wheel nuts for my sons arrma outcast
The part number is arac9698. 5x8mm. They seem to be out of stock everywhere. Anyone know of a place they think I might be able to find them and order them? Thanks in advance!!!
HPI Z680 old, newer, axial 31087:
Guessing either would work as well.
Warranty parts came in today. As far as the HR, yes those are the ones I got and I haven’t had any issues since the install. Got mine off eBay since they are out of stock everywhere else. Not sure if regular nuts would work, would have to check the pitch and depth of the threads against whatever you planned on using.
Thanks for the info. My wheel nuts fell off a couple times. I'm gonna try some blue loctite. If that doesn't work then I will get the HR (if in stock). I just hate spending that much on wheel hexes.
Understood, if it helps make the cost easier to swallow the additional width has a small effect on cornering as well. I can turn on blacktop without having to use quite as much brakes. Something to consider!
