Combatjeep
- Thread starter
- #21
I can't imagine what could have gone wrong without even running it. My first run went fine, then I put the skids on and poof.... One direction steering.Contact Arrma support they are pretty good about replacing failed parts (or at least they have been for me), but it might take a few weeks for you to get the replacement part. I broke a lower rear suspension arm on my first run with my Big Rock. Arrma replaced it at no charge, but it took 4 weeks for the part to arrive. I ended up buying a set at my local hobby store so I could get the truck back up and running faster. Which wasn't a big deal for a $10 part, but a steering servo is more expensive so it might be worth it to wait for that. I am not sure what your plans are for the truck, but if you plan on putting larger wheels and tires on you might just want to get a better servo anyway. The stock servo works, but like I said before it's a bit under powered for any kind of surface that is really loose or soft. I have not replaced mine yet, but that is probably the next upgrade I will do to my truck. I think I will probably go with the Blue Bird BLS-H50B, it is rated for 620oz-in @ 6.0V and 0.12sec operating speed and the price seems really good for the specs. @Havoc put one of these in his Nero and said it was a good servo except that it got water damaged which is the one thing that is kind of weird about this servo. Some post say it's waterproof others don't say anything at all. Anyway, there are a number of other forum threads that people talk about the servo's they have upgraded to if you just look through the Nero, Big Rock & Fazon threads. A lot of people like the Savox servo's. @BigSilly450x went with the ProTek 370TBL, which is probably my second choice if I don't go with the Blue Bird. The ProTek is a bit more pricey though.
