Big Rock Needing input on wing wing mount and wheelie bar
Shane85
Got a big rock 3s wanting to put a wing on and different wheelie bar any ideas what wing wing mount and wheelie bar would work
The 4s mount looks completely different is. So not 100 % sure. But most wings are interchangeable. Wing's Body clearance just may be an issue, depending.
Will the outcast 4s wheelie bar work for the big rock crew cab wanting wheelie bar like that
Don't think the outcast 4s will work. The Granite and Big Rock are the same. Jennysrc.com has both.
V1 outcast mount, wing, and wheelie bar will bolt right up.. once you have the mount, you can put any wing you would like on it.. all the wings, 3s, 4s, 6s have the same center to center bolt pattern.. so many to choose from..
V2 is different so don't bother..
Doesn't sell 3s 4s wing mounts that I know of.. 🤷
V1 is the same as all the rest.. recommending parts for a granite and bigrock will yield no results.. they don't come with wings or mounts.. 🤷.
EDIT: I apologize, I misread your post .. you didn't recommend any parts for the granite or bigrock, sorry my fault.. reading through fast at work...🙏
Correct.. v2 is different.. v1 is direct bolt on as they are all the same..
Anyone got a pic of the v1 outcast mount wing and wheelie bar trying to make sure I get the right one
Just go to Arrma-rc.com and look it up . Pictures and all.
That is your bible. Parts support is great there. Learn your way around. Lists crossover parts etc.
Could someone maybe post a pic with part number for the v1 outcast mount wing and wheelie bar please and thank you not seeming to find it
Outcast wing
Whole set up.check to see if it will adapt
Outcast wing
Ebay
Yes your correct
Except for the wheelie bar..on the big rock you don't want that wheelie bar set to the wing .I would leave it where it's at stock..he really just needs the wing mount and the wing..the extra wheelie bar wheels will come usefull when he wears down his stock wheelie wheels.in the long run it's cheaper to buy that whole set up so he doesn't spend more on a set of wheelie wheels in the future.on my big rock I removed my wheelie bar ..no need for it as I converted my big rock to a speed runner and the stock wheelie bar won't work with the set up I have.going to buy a long wheelie bar for drag racing made of aluminum.
