nero..big rock..fazon
gregmbrandt
not quite ready but close...new rocker posts that are alot stronger ..not hollow all the way down.... IMG_20161214_075501.jpg
gregmbrandt
I recommend using 5mmx35mm bolts and small washers to go between the bulkhead and bottom bearing
Tblazin
NORTH JERSEY
BigRock, Talion
funny you should say that, as I installed the acer bearing, they give you 8 for the rockers, they spun out with screw?? didn't look that far into it, so its the cantilever coming loose, I have the hobao ends, so that rids that issue, so I'm fine without those metal levers.
Tblazin
NORTH JERSEY
BigRock, Talion
or will just getting those gka posts eliminate it all together????
they seem to not be hollow?
Create account
Log in
