Great price for a back up or other use
I'm just clearing up a mis conception.. the Nero comes default at 7.2v... you can change it to 6v.. changes to the LVC is not adjustable... BEC voltage was verified by a fluke meter
its clearly stated in the manual...the dark gray shaded areas are factory defaults...7.2VI've never seen any documentation that it comes defaulted to 7.2. The manual even says 6.0 because the diff brain servos will fry at HV.
-c
you canThanks for the heads up. Makes me wonder if they're going to be replacing it with something more programmable? Lots of people don't like the fact that you can't change the 6v bec setting to 7.4 for the servo.
Not on the BLX200! I looked in the manual for my Fazon and it's not even an option...Looked on Arrmas website and same thing. If you know a trick let us all know! Better yet, can you post a picture of that page in YOUR manual. Mine must be missing that part. Thanksits clearly stated in the manual...the dark gray shaded areas are factory defaults...7.2V
you can
Well damn, look what I found. Seems you were correct and I apologize....My non diff nero manual and my fazon manual are different.Not on the BLX200! I looked in the manual for my Fazon and it's not even an option...Looked on Arrmas website and same thing. If you know a trick let us all know! Better yet, can you post a picture of that page in YOUR manual. Mine must be missing that part. Thanks
Probably why there's 2 different BLX200 ESC's. Hope this helps someone! Might be something to look into when getting a replacement. If the Diff brain will indeed fry @ 7.2 then this might need to be posted somewhere so everyone can see this before doing damage to their vehicle!I've never seen any documentation that it comes defaulted to 7.2. The manual even says 6.0 because the diff brain servos will fry at HV.
-c
IDK?How can one tell the difference when for sale? It is a great budget Max8 if you can run HV servos. Tower is saying the one for sale now is 6V.
-c
