Premium members don't see ads. Click here to upgrade.
Nero goes into low voltage cut off for on full batterys
RCMANIAC147
Nero
My Nero keeps acting like it has low batteries (slowing down then not moving) then after a while going back to normal speeds and repeating the cut off process. This is happening on full charged batteries. I reset it to factory mode, the same. I narrowed the problem down to my servo, when it’s un plugged it doesn’t go into Lvc. The servo savox I’ve had in the truck with no problems for a very long time. Is this the servo or maybe something with the esc?
6SPOWAHHH
Nero,
ive read savox servos can be power hungry. that could be your issue. i don't have any experience with a savox on the stock esc but i have a savox 1210 on my crawler w/ aftermarket bec and have had no issues.
install a bec and see what happens. im running the castle 10a bec, it works great. it runs about $20
id reset the truck back to factory settings first though, both esc and transmitter. throttle endpoints too
RCMANIAC147
Nero
Thanks. I reset the esc to factory I’ll do the transmitter also.
RCMANIAC147
Nero
One thing I don’t get is how I was able to bash with no problems for a very long time then this started to happen halfway through one bash.
slick2500
Will work for beer.
ArrmaForum Fan
Rapid City, SD
Outcast 6s, Typhon 3s
Either servo is going bad or the BEC in the esc is going bad would be my guess. If you have another servo to test with give it a try.
Similar threads
