- Thread starter
- #61
Just wanted to revisit/update the Nero motor with BLX185 ESC. As you guys probably know, specs are very similar between the BLX185 and Nero BLX200 ESC. Think I took a bad gamble choosing to cut my motor wires/leads and swap 5.5 mm Nero connector for 4 mm to fit all my 185 ESCs. Really should have cut ESC side and placed 5.5's on the 185 ESC. While this combo has worked fine in the Kraton, my Outcast has began to really heat up and has started cutting out on me. It will resume working after a bit, but motor temps have jumped to 160-175F with identical gearing and setup in Outcast as I'm running in the Kraton, ESC hits115-130F. Only difference is I run 100k center diff fluid in the Outcast, 200k in the Kraton. In any case, pretty sure I upset the motor timing by altering the wires. Just throwing this out there as an FYI.
