Nero universal joints
golfjunkie327
Michigan
New nero with diff brain. On the second use i snapped the pin that hols the u joint together. The one by the differential. I had the hobby store order me new ones. The heavy duty ones. Not sure of brand. Can anyone recommend a good quality brand for the heavy duty u joints for future repairs ? Thanks in advanced.
puh, difficoult..
Maybe check the Big Rock or Fazon parts. Arrma sounds they should be hd.
Do you had an blocked axle? normally the pins should break to prevent the joints from damaging.
puh, difficoult..
The pin on the yolk sheared off. I just got a call frim hobbie shop parts are in. They are made by arma and are hd compared to stock ujoints
puh, difficoult..
If im correct, there ate 2 pins. One small on large on the ujoint itself. The small one snapped. Not the hub.
