New!!! 40mm to 50mm motor can shock absorber
3d-rc.myshopify.com
Eat,sleep and breath Arrma
Hospitality Award
Michigan
  1. BigRock 4x4
  2. Granite
  3. Infraction
  4. Kraton 8S
  5. Kraton 6s
  6. Notorious
  7. Senton 6s
  8. Senton 3s
https://3d-rc.online/products/motor-support
Don’t forget to use code: arrma forum at checkout for instant savings.
I noticed that before I read your post. How does this work? The v4 and higher MM have a height adjustment when you change gearing. How does this product adjust for that?
I was wondering the same thing.
It’s spaced at 5mm below the can if needed to be smaller there is a ring that can be trimmed off to make it shorter. Even if it’s taller then the 5 mm i haven’t come across a combination taller then 7 mm so it will still do a great job absorbing impact instead of slapping off the chassis. If you want anything specific just let me know your measurements and I will make one to fit exactly.
