AustinKraton
I would say from Cheap to Expensive:Got my second ARRMA...
Any tips or tricks. Is the radio that bad?
Planning to swap it out.
I agree to upgrade as needed, this buggy is a beast out of the boxCongrats on your new rig
The typhon really is a blast. I'd recommend swapping the radio ASAP. Depending on your drivestyle, I'd upgrade stuff when it breaks. Also, I can really recommend to truggify it, it's even more fun then
What he said!Standard upgrades list always applies. Chassis braces and servo mount to metal is always a good first choice. The braces especially since the Typhon cannot benefit from a typical tower to tower brace. Planning on running hard in the dirt, then definitely consider a bearing swap. I also feel that as good as Arrma's are, the suspension mounts/hinge pin holders could use something better than plastic with that thin aluminum strip underneath. Other than that, most of the 6s trucks are good to go out of the box, minus the radio.
Yes the Tactic is a fine radio. It is a simple, one car radio. If you want to be able to use it with multiple cars or have a lot of features, then it won’t work for that. But if all you want is a basic but quality radio, the Tactic is very good.Just bought my son a Typhon 6S. Is the Tactic TTX300 SLT not a good replacement anymore? I had read previously that the Tactic worked great for this buggy.
https://www.amazon.com/dp/B00SLO64D...B3&psc=1&ref_=lv_ov_lig_dp_it#customerReviews
Any tips or tricks.
