Plus you get a new case/bulk head everytime you buy a diff. from Jenny's for less then a rebuild kit. If Arrma puts out metal cases that won't cost as much as a truck EZPay payment, looking at you HR, then I'd might change all 3. Like my truck isn't getting heavy already.Since I have extra difs from buying complete ones from Jennys, I have lots of spares and I can't see why you would change all three. I bought two Hot Racing ones for the center dif because they are exposed and get destroyed by rocks and gravel. The ones inside the gear box all look brand new after cleaning and servicing. Even ones that have had a gear blow up inside, were still fine once cleaned. If I didn't have the HR's,I might have got these because they're a bit less money, but only for the center dif.
One tip about leaky diffs btw, is to make sure there is no air bubbles inside when you put the diff together, air will expand when the diff gets hot, creating pressure inside and causing the diff to leak. Relevant to both the metal and plastic diffs
Oh, regarding that, yeah, they are not needed.Not the reply I was hoping for , but good tip, thanks anyway
What part are there no slots for?Hi Guys, had nothing but trouble with my Talion v4 leaking from the centre diff so decided to buy the aluminum case. Just tried to swap over parts from the old diff and noticed that there are no slots for the metal support inserts, which are to long to fit anyway, everything fits nicely without them !!!!! is this right ? Help please.
You give /sell one to your poor brother from north of the boarder??I've had the plastic diff cups stretch over time making the internal mesh loose, this would solve that. I now have 4 6s Arrmas what should I do?
I've had offers on my Kraton "Race Spec" already, might be a good idea to sell it while I can, Haha.You give /sell one to your poor brother from north of the boarder??
looks like there will be steel gears and pins rubbing on softer aluminium directly
Does it seem like it needs the second shim behind each planetary?I understand that these are now disgarded
Thanks for the pic, I have already assembled mine but with only one shim. You have probably saved me from an early strip down.
