slick2500
Anything will break if you drive it wrong enough.
Community Leader
ArrmaForum Fan
- Rapid City, SD
- Fireteam
- Kraton 6s
- Kraton EXB
- Outcast 6s
- Senton 3s
- Typhon 3s
Here's the sad part Hobbywing also makes the Spektrum escs. So it is something that Spektrum does on their end that messes them up.Nope, Traxxas back in the day used Castle ESCs. Corally uses max8, max10sct, & max10 ESCs. Hobao 6s ESCs are well binned & I'd use them over Spektrum any day. Redcat & Team Magic also used max6 & max8 clones. Arrma used a max8 clone in the Nero, but it was way too watered down. As for servos, both Corally & Hobao use coreless digital servos but both are beat by the 35kg Amazon special.
I've had that problem with those servos too.I have seen 400$ esc from hobbywing and caslte blow up in flames. Some casle motor bending because of the set screw of the pinions. Everything is kinda crap when it comes to electronics in the first batches
The coreless amazon servo give way too much before they start to hold
You can move the horn by hand on them a fair amount before it locks up
