RadicalTireSkid
- Granite
Ok so I've had this BLX running 3s for about 3 weeks now and probably have about 10hrs on it. I've traditionally ran Nitro cars in the past but decided to break into electric.. what a great choice.
I have a few questions/issues that hopefully you guys can help.
1) I bought a onyx 5000mah 30c batter. Initially I thought this was okay based on small amount of research but the granite manual states I apparently should have a 35c battery. A local hobby shop guy said it should be fine.
If I continue to run this battery, will I cause issues with the car?
I'll also note I made some mistakes already with this battery. 1, I charged it right away and realized the connector was wrong (figured connectors would be standardized.... ha. ... ha...). I let it sit about 48hrs before discharging it with an LED light. AND THEN I found out your not supposed to discharge them too much... so yea. I left it on the light for probably way too long (20W light for about 8-10hrs).
2) Recently I'm getting more confident with the car and I've been running it a lot at 100% throttle and high speeds on the street and open fields. I've found that after doing a bunch of these runs, the car likes to go into limp mode prematurely. If I shut it off for a bit and run it again, I can get a good 5-7 min runtime out of it. I'm thinking its the battery being overstressed but not 100% sure. I'm ordering a better battery today.
3) It seems like the left rear differential seal is weeping oil. Its been doing that for about a week now. Not much, but I can notice it a bit after cleaning (I blast the car off with air after each run to keep it clean. I focus on suspension joints mostly).
Is this normal? Should I send it in for warranty?
Thanks for any answers. Again, I'm new to electric RC so kinda learning the basics. Should have joined this forum earlier I suppose.
