Boomer
Afternoon all. Just finished painting a 1976 Ford F150 shell for the big rock. Couple of minor paint bleeds but overall, not too bad. Need to charge up and go for a drive now!
We're gonna need a bigger boat!
Thanks. Not a lot of choice out there for the big rock and I wanted something a little more retro. Only thing I could find that fit!Body looks sweet! Lines up perfect also with the wheels great job! Not a Ford fan but again this turned out great that side view is
The bumpers are separate part of the body (Carisma f150 shell) which you then attach, so no painting needed fortunately! I used pin stripping tape to create the lines on the bed. Removed them after the red, then used anodised silver ps48 tamiya paint.Wow! Looks fantastic. How do you get the chrome effect on the bumpers and bed strips? I wanted to the front bumper of my c-10 chrome but I just went body color. I was thinking nail polish or something but I thought it wouldn’t look right. Is there a spray that you used? My hobby shop didn’t have any chrome offerings.
Oh I see. Did the mirrors come with the body as well? I’ll have to order up that paint and try it on the next oneThe bumpers are separate part of the body (Carisma f150 shell) which you then attach, so no painting needed fortunately! I used pin stripping tape to create the lines on the bed. Removed them after the red, then used anodised silver ps48 tamiya paint.
Oh sorry just re-read yore post. CarismaOh I see. Did the mirrors come with the body as well? I’ll have to order up that paint and try it on the next one
Wow I just noticed the wipers too! That is so cool. What brand of body is that? Did it come with the accessories like mirrors bumpers and wipers or is that all separate?
Yes, all the accessories (mirrors etc) come with the body. It's not particularly practical for bashing, but I've got enough of those type of bodies so thought I'd have a good at something a little more scale for street running. Got some lights coming for it which hopefully will look ok.Oh I see. Did the mirrors come with the body as well? I’ll have to order up that paint and try it on the next one
I usually run a wing on which means the mount has to sit a little higher to clear the body. But it's just a case of taking the wing mount off and dropping the body posts again if I wanted it to sit flat. 2 minute job.I wonder if you switch the rear body mounts to some from this set:
https://www.arrma-rc.com/part/AR320357
If it would allow the rear to sit down flush?
I got the body mount kit when I did my new body but it sit down level and I didn’t have to use any new posts. Just a thought, you might like the raked stance better. Looks good either way!
Love that wing. Can you post a link to it where to purchase?I usually run a wing on which means the mount has to sit a little higher to clear the body. But it's just a case of taking the wing mount off and dropping the body posts again if I wanted it to sit flat. 2 minute job.
Thanks. It's the Typhon 3s wing. This YouTube video shows you how to do it and what parts you need. Part numbers etc in the description. You can fit an outcast wing as well if you want a slightly smaller one.Love that wing. Can you post a link to it where to purchase?
Thanks man! I love the way it looks. Size seemsThanks. It's the Typhon 3s wing. This YouTube video shows you how to do it and what parts you need. Part numbers etc in the description. You can fit an outcast wing as well if you want a slightly smaller one.
Thanks for your suggestion. I actually have it and planning to install once I`m done with repainting the bodyIf you want to further protect the body you can also add the outcast 4s roll hoop. Some like it, some don't, but it definitely helps.
For your wing, did you shave down the body posts to make it fit flush? I have a typhon 3s wing/mount to fit on mine as well but haven't installed to see where I need to cut yet.If you want to further protect the body you can also add the outcast 4s roll hoop. Some like it, some don't, but it definitely helps.
